configure ip-security anomaly-protection notify rate limit
configure ip-security anomaly-protection notify rate limit value {slot [slot | all ]}
Description
Configures the rate limiting for protocol anomaly notification.
Syntax Description
value Specifies the period of the rate limit.
slot Specifies the slot to be used.
all Specifies all IP addresses, or all IP addresses in a particular state.
Default
The default is 10 events per second.
Usage Guidelines
This is a paired command with configure ip-security anomaly-protection notify rate window that configures the rate limiting for protocol anomaly notification. When the anomaly notification is enabled, in order to avoid overloading CPU, the system generates only the number of limited notifications in a period of window seconds. The range is from 1 to 100 events.
This command was first available in ExtremeXOS 12.0.
Platform Availability
